1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Welcome to Speak EV, the electric car forum for all EV owners and enthusiasts.
    Our aim is to create the best, most inclusive EV forum for all makes and models of electric car.
    We'd love for you to join up and join in. It's quick, simple and free! Join Speak EV.
    Dismiss Notice
Electric 911!!
Discussion in 'General EV Discussion' started by henryv, Oct 19, 2016.
  1. henryv
    henryv Well-Known Member
    445
    336
    EV:
    Nissan LEAF
  2. Siraff
    Siraff Well-Known Member
    1,823
    1,013
    Well they did a beetle so this shouldn't be too much of a stretch for them. I wonder if they are going to go for a load of power or keep it similar to the beetle?
  3. henryv
    445
    336
    EV:
    Nissan LEAF
    Well!
    It it is my car, so I will keep everyone up to date, as much as I can!
    We are looking at a 54 Kw battery - so are hoping for 200miles plus?
    I am sure we will have more power than the Beetle.
    The Beetle is pretty powerful in it's own right!!
    It is in the very early stages and parts have been ordered.
  4. Spirit Driver
    Spirit Driver Well-Known Member
    3,258
    1,873
    EV:
    Nissan LEAF
    To have more power / speed / acceleration than the Beetle I assume you just simply fit a more powerful / faster motor ?
  5. BrianM
    BrianM Well-Known Member
    1,024
    501
    You will need a bigger battery to allow the higher current draw too (depending on the weak point of the system of course).
  6. henryv
    445
    336
    EV:
    Nissan LEAF
    2 motors?
  7. Siraff
    1,823
    1,013
    Or powercaps?
  8. Siraff
    1,823
    1,013
    Oh and by the way I really liked the Beetle. Looks very well finished and not the usual bodged together mess. Nice bit of quality workmanship there. (y)
    henryv likes this.
  9. henryv
    445
    336
    EV:
    Nissan LEAF
    What are powercaps Siraff?
  10. BrianM
    1,024
    501
    I'm guessing capacitors to give a short burst of power.......maybe.
  11. Siraff
    1,823
    1,013
    Power capacitors. They act as dry storage so they take up more space per kWh than is reasonable for an ev but they do have some very nice sides. They can charge/discharge at massive rates - almost instantly with the correct supporting hardware. That means you could have a couple of kWh of power capacitors constantly being charged from the battery which could then give burst power of whatever they hold - so say you want to dump a kWh through the system in a few seconds, that would be possible. The power capacitor could then recharge at a rate the battery is happy with - obviously with the power only being available as long as the capacitor/s have some left in them.
    For a car like this I think they could provide an ideal solution since you only need a low C rate for normal driving but could still have massive burst acceleration from the assistance of the caps.
    The Riversimple uses them but that's more because it doesn't have enough power to accelerate properly without. If you already have normal power they are just a big bang bonus for the odd blast here and there - they also allow collection of massive currents for regen.
    I think they would really suit the sporty nature of that 911 and added to 54kWh it would have a brilliant mix of range and power.
    MetalHead and henryv like this.
  12. henryv
    445
    336
    EV:
    Nissan LEAF
    Thank you!!;)
    Siraff likes this.
  13. Spirit Driver
    3,258
    1,873
    EV:
    Nissan LEAF
    Basically what you'll find inside powerful modern photographic flash guns.
    Charge within seconds from batteries, and then produce a huge surge of power, enough to illuminate a considerable area, instantly when called upon.
    Siraff and henryv like this.
  14. henryv
    445
    336
    EV:
    Nissan LEAF
    Do any other EV's use these?
  15. davidr1963
    davidr1963 Active Member
    187
    132
    Do you mind me asking what the approximate cost of the conversion is likely to be, there are a few cars I'd like to have as an ev!
  16. henryv
    445
    336
    EV:
    Nissan LEAF
    It's too early to say David.
    There is the cost of the car, and it's condition, which will be a big part of it.
    The type of finish you require etc.
    The batteries depends on your requirements.
    Richard prefers cars from the 60's or 70's.
    Mine is a 1979.
    Best way is to select your car of choice and ring Richard to discuss.
    He is a great lad, and will give you an idea of the cost.
    I would speak to him first before you buy anything, for his thoughts.
    richard@electricclassiccars.co.uk
  17. HandyAndy
    HandyAndy Well-Known Member
    1,160
    764
    Winchester
    EV:
    Vauxhall Ampera
    Not sure, but they take up a lot more space volume-wise than LiOn batteries do, and they're v expensive in $/kWh compared to batteries. So might not be the best thing in a space-limited sports car, especially if trying to cram in nearly 60 kWh of cells as well. If you want to use them to supply vast overtaking surge of power, you need to be very sure that you have enough charge stored in them before you start the overtaking manoeuvre - running out of the boost as you're half-way past a large truck & going uphill might not be funny. At all.
    Take a look here where I worked out a 10kWh supercap battery design, to see how it would compare to my Ampera's 10.4 kWh useable LiOn: The 500 mile EV
  18. henryv
    445
    336
    EV:
    Nissan LEAF
    Thanks Andy!!
    They will be Tesla batteries.
    Part of the early work will be using weights to find the best locations, and to see the effect the batteries have on handling.
    We will need better front brakes and suspension, and a stronger anti-roll bar.
    The batteries themselves may be 6 weeks by boat!!!
  19. Siraff
    1,823
    1,013
    The riversimple rasa does. That's more of a dicey attempt at getting funding than a serious car but it shows ho useful capacitors can be since it only has tiny hp but can still accelerate reasonable while there is power in the caps. It's biggest flaw is there's not enough power in it to charge the caps and drive normally so it's kind of a downhill circle until it's left with about 11hp.
    No idea if other ev's do but if you want to avoid high C for short bursts they are a brilliant buffer.
    A 54kWh would let you use 160-ish kW without issue which for normal driving is fine anyway. On the other hand if you have say 3kWh worth of capacitors, you could in theory blast out 180kW for one minute bursts. Obviously that would be over and above what the battery could already provide so after taking in losses, that 3kWh system is able to double power for upto a minute or so - in reality you would probably want to restrict that to less as heat build up would be pretty high in the rest of the system. That takes it from a respectable power level to a similar amount to a 996 turbo. I doubt you would want to hold that kind of power open for more than 30s or so anyway - certainly not if you like your license.
  20. mgboyes
    mgboyes Well-Known Member
    3,800
    3,140
    EV:
    Renault ZOE, Tesla Model S
    I've never had the slightest interest in classic cars - but the idea of taking one and fitting a 21st century drivetrain really appeals. It will be fascinating to see how the 911 turns out.
Loading...
Share This Page
