1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Welcome to Speak EV, the electric car forum for all EV owners and enthusiasts.
    Our aim is to create the best, most inclusive EV forum for all makes and models of electric car.
    We'd love for you to join up and join in. It's quick, simple and free! Join Speak EV.
    Dismiss Notice
iMiEV/C-Zero/iOn range
Discussion in 'General Mitsubishi EV Discussion' started by Robwiz, Dec 24, 2014.
  1. Edd Beesley
    Edd Beesley Moderator
    6,017
    4,290
    Corby
    EV:
    Nissan LEAF
    But he wouldn't be able to do 60mph behind a lorry, as they mostly travel at 56mph.
  2. stuart
    stuart Active Member
    439
    87
    Had this idea since purchase of czero four years ago. At the front of car the radiator with electronic fan, when is this ever used as in fan or the rad required also including summer months. The issue I am no expert if the rad and fan for almost 90% of the year is not used block it of. Aerodynamically as the hole for rad is stuck on the front of car must be better.
  3. John419
    John419 Active Member
    331
    162
    EV:
    Citroen C-Zero
    What, if any, effect does the number of passengers have on the range?
  4. Edd Beesley
    6,017
    4,290
    Corby
    EV:
    Nissan LEAF
    1-2 miles per adult passenger.
  5. John419
    331
    162
    EV:
    Citroen C-Zero
    Thanks. I live alone so will mostly be the only occupant.
  6. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    Then my
    My clock lied to me :D
  7. KenB
    KenB Active Member
    107
    54
    EV:
    Peugeot iOn
    Stuart,
    I also had the thought of blanking the rad off in winter but do not think it is a good idea because the rad is for controlling the temp of the motor by liquid cooling. The temp of the motor will be linked to its effort and have very little correlation to ambient temp.
    I have tested the range of a full charge at various speeds 70,60,50 mph at constant speed on flat road of single distance 11ml by doing 2 return journeys ie a total of 44mls . This removes errors from wind and gradients and left overs from the run before.
    The result is
    70mph gives 45mls range ( power needle just pass the vertical)
    60mph gives 68mls range (past "o" of eco )
    50 mph gives 80mls range (needle between e and c of eco )
    This corresponds to air drag being proportional to v*2
    I guess one could do 100mls at 30mph but i am not the one to do that on a busy dual carriageway!
    The range guessmeter only uses the data from the last 5ish mls driven I believe and bears little relevance to a future journey.
    Ken
  8. stuart
    439
    87
    Has any looked at present battery's LEV50N, does anyone have any info on the Yuasa LEV75. It seems impossible to buy them, would the present vehicle accept a higher density battery.
  9. Mark Cornwall
    Mark Cornwall Well-Known Member Speak EV Supporter
    506
    416
    Newquay
    EV:
    Kia Soul EV, Peugeot iOn
    Seem to remember some mentions of this on imiev forum a while back. Imiev and clones batteries are lasting really well though. For example currently at 5 years old and 94% so replacement may be some way off.
  10. KenB
    KenB Active Member
    107
    54
    EV:
    Peugeot iOn
    In terms of battery/motor management i am beginning to think this car is underrated.
    The way the battery temp is actively managed/fan cooled and even using the air conditioning when fast charging.
    The motor is liquid cooled.
    I am wondering if the battery capacity meter does not go down to absolute zero and this is the reason the Japanese tested range is greater than perceived and this is done to protect the batt
    Ken
  11. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    I did 100 miles with my iOn few years back, I've been going between 25-40mph on not busy a road in East Riding of Yorkshire
  12. stuart
    439
    87
    Supposedly the LEV75 has 50% extra density if true the clones would be then become a very interesting car. Obviously you need to find them buy them and install plus keep fingers crossed.
  13. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    imiev Japanese version has just 10kwh battery
  14. stuart
    439
    87
    I don't think we can answer question.
  15. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    What's the difference between 50 and 75?
  16. stuart
    439
    87
    75 supposedly 50% extra density.
  17. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    What about availability and size in kwh?
  18. stuart
    439
    87
    Sainsbury were selling them online coupled with a free Leaf thrown in. Kwik Fit are now offering 30 minute batts replacement.
  19. Nero
    Nero Active Member
    455
    113
    Scunthorpe
    EV:
    Nissan e-NV200
    Very interesting and informative post, I'm sure the other forum members will find it funny and useful, as soon as their batteries will degrade, which won't happen anytime soon. Be proud of such a good answer, I'll give you thumbs up for it
Loading...
Share This Page
