The battery health thread!
263K views 2K replies 242 participants last post by  Chrisb
#1 · (Edited)
*** Xaccers links to Google sheets for data entry and up to date graphs below. This supersedes the original graphs I was maintaining. Cheers Xaccers!***
Xaccers wrote:
"In response to the chart showing faster degradation for 30kWh batteries, I've created the following if people with LeafSpy in the UK would care to add their figures:
30kWh Leaf
Data entry form: 30kWh Leaf age and health
Chart of results: 30kWh Leaf age and health
24kWh Leaf
Data entry form: 24kWh Leaf age and health
Chart of results: 24kWh Leaf age and health
It also includes Hx figures if you have them (currently trying to get confirmation on the 30kWh 2 year old leaf with 99% SOH but 45% Hx!)"
Simon
See less See more
2
Gen 2
March 2015
9025
95%
QC 112
L1/L2 221
One point to note though. Almost all of my L1/L2 charges are carried out overnight on the timer. I've noticed that this counter increases by 2 for each charge. It counts the 1 second after plugging in before the timer shuts it off. Then it counts again when the real charge actually starts. So the actual number of L1/L2 charges would be nearer to 110.
#4 · (Edited)
Here's the plot of the data I have so far. Quite a good correlation of SOH with age I think, considering there are lots of other factors in the mix. Compared to some data from early USA cars I found, we can expect batteries in the UK to last twice as long :)
#9 ·
It is a crude measure but the year to year summer seasonal best on the GOM is another indication (if not using LeafSpy). Last year GEN2 at 6 months old GOM best on 106 miles, (1600 miles driven) this year 102 on the GOM at 18 months (5800 miles driven). About a 4% annual drop which seems to be on trend. Looks like BEVs are use or lose. Not good for small annual mileage drivers. It makes battery depreciation at 4% per annum of a replacement costed £5000 running 4200 miles a year twice the cost of the electricity per mile.
Does this mean the second hand market should value and price on SOH more than mileage?
We'd need a LOT more data to get a meaningful surface plot. The data we have would give a wiggly line in XYZ, not a surface.
I have done a plot of miles vs SOH: not such a good fit on a log best-fit rather than linear. Here we see more of a difference between Gen 1 and 2 perhaps-
Text Line Font Plot Number
Reactions: Mr_G
These are from my Gen1. It was registered May 2012, but I found out it was built about a year earlier.
Date/Time,AHr,Hx,Odo(km),QC,L1/L2,Ambient,SOH
09/12/2014 19:07,609292,84.27,9596,12,375,17,92
10/29/2014 18:31:45,603979,82.38,12267,17,458,7,92
11/24/2014 18:46:23,601814,81.93,14019,26,519,2,91
12/18/2014 23:02:02,604897,83.7,15844,35,583,11,92
#15 ·
And these are from my Gen2. Built 22nd December 2014
Date,Ah,Hx,Odo(km),QC,L1/L2,SOH
01/21/2015 18:46:25,651907,99.83,315,1,11,99
02/13/2015 7:15:37,673620,107.59,1773,3,64,100
03/03/2015,672573,109.16,3159,7,109,100
04/27/2015 18:17:40,673620,103.88,6441,17,210,100
06/02/2015,673620,103.88,6441,17,210,100
06/29/2015 18:41:07,650010,99.48,9858,35,294,99
08/04/2015,673620,104.86,12729,52,367,100
09/09/2015,673620,103.88,6441,17,210,100
09/09/2015,629867,96.82,14565,63,427,96
07/11/2016,613909,94.58,30610,141,855,93
#18 ·
Gen 2
March 2015
9025
95%
QC 112
L1/L2 221
That's a real shame from a data analysis point of view, so we've no way of knowing how many charges a battery has seen!
Gen 2 Dec 14.
I have a few data points to help:
7/15 3,593 miles, AH 59.63, SOH 91%
8/15 4,101 miles, AH 59.42, SOH 90%
5/16 15,230 miles, AH 60.18, SOH 89%
7/16 19,013 miles, AH 59.59, SOH 89%
The charge counter does not count cycles, and double counts when using the timer. So worthless for our purposes.
We can use miles as a reasonable alternative (only if comparing like size batteries). Assuming an average 4.3 miles per kW and an average pack usability of 20kw (for 24kw pack).
Gives you approx 116 cycles per 10,000 miles.
#22 ·
Gen 2 Dec 14.
Thanks - your data is far more in line with my car so it makes me feel better and must be correct ;)
#26 ·
The 80% recharge cutoff option has been removed since the mk1. It has been suggested that this is not a problem with the new battery chemistry. I don't believe that it's OK to charge the battery to 100% and leave it for any period of time.
I have been looking into how to achieve this but currently just unplug the car before it is fully charged.
#30 ·
How old is the car exactly Chris? 91% is about right, but you can see from the graph (first post in the thread) that there is a large amount of scatter in the data.
